No maps at all on Mac il y a 8 ans 2 mois #150
Hi, I download the following files on my MacPro (Mac OS High Sierra 10.13.6) : XyGrib-mac-zip 1.1.0 & xygrib_maps2.4.tgz.
I'm unable to ses any base maps, just bleu scree with grid. So where I missed something?
Thank
RobChabot
No maps at all on Mac il y a 8 ans 2 mois #151
Hello Rob,
It might be that the maps folder got trashed when you added the high res maps.
It is important to keep the structure under the installed location that has:
<install foder>/data/maps/gshhs/
This is the original folder structure and if xyGrib_maps2.4.tgz is uncompressed in the <install directory> the structure should be kept.
You might want to reinstall XyGrib - test it before adding the hires maps and then add them to the correct location (overwriting some existing files in the gshhs folder).
Please let us know if this helped.
No maps at all on Mac il y a 8 ans 2 mois #152
Hi David, thank,
I trahed all my xygrib files and reload the software. I installed just the XyGrib-mac-zip 1.1.0. files
The structure is correct : XyGrid folder and within : data/maps/gshhs/gshhs_2.rim...etc
But no base map again!
Regard
RobChabot
No maps at all on Mac il y a 8 ans 2 mois #153
Can you please load a grib file and tell me what displays. Preferably use a pre-cut grib file. You can download any one from openskiron.org.
After loading the file, please select "Earth->Zoom (selected area or grib)"
Have you tried using the Mac pkg to install instead of the zip ball?
No maps at all on Mac il y a 8 ans 2 mois #154
Yes, i have use Mac pkg.
When I download a grib file from Openskiron.org (europe) and then, use the Open command towards this file, it's work : I saw winds arrow, etc.
So what now since I can't choice my area on a base map?
Robert C.
No maps at all on Mac il y a 8 ans 2 mois #155
Sorry I'm a bit late at getting back to you.
It appears that the application cannot find the maps folder in the folder tree under "data". The entire tree starting with the "data" sub-folder should be in the same folder as the executable XyGrib. Also please check if the maps folder exists and if it contains gshhs maps.
Are the icons in the toolbar also missing?
